Golf Mk1 GTI
PEXBOY
Re: Golf Mk1 GTI
Mensagem por PEXBOY »
Vai ficar porreira esta montagem...
he he... esses colectores são uma malha!
DieselPower
Re: Golf Mk1 GTI
Mensagem por DieselPower »
boa escolha.....os meus gti's também usam disso.....1 deles vai deixar de usar LOOOL
Nitrox
Re: Golf Mk1 GTI
Mensagem por Nitrox »
Patitos Escreveu:PESSOAL PRECISAVA DE UMA AJUDA RAPIDA "
"The HICON TX “plus” coilover kits have been designed for sporty and ambitious drivers, who want to adjust the damping rates of their rides.
Rebound adjustable without dismantling the dampers
TX “plus” – state of the art technology for a long product life
Reduced system-friction for effective rebound adjustment
Individual lowering within the TÜV approved lowering range
Front axle and rear axle (if technically possible) with coilover
adjustment
Galvanized strut housings with additional coating for ideal
corrosion prevention
Complete solution with adjustable spring perches, race spring
system and rubber stops with dust protection cover.
OU então :)
Variant 2 and personalized with adjustable rebound damping
The system intended for the experienced driver who requires to not only determine the individual lowering of their vehicle, but adjust the damper setting to fine tune the system to their needs. The adjustable rebound damper allows adjustment of the pitch and roll behaviour of the vehicle, adapting it to one‘s own driving preferences.
Damping technology with individually adjustable rebound
inox-line stainless steel technology at no additional charge
Individually height adjustable
German TUEV-tested adjustment parameters
High-quality components for long life
Comprehensive documentation for ease of use
Infinitely adjustable rebound damping
Na vossa opinião qual o melhor :?: :?: ~
São praticamente idênticos a nível de funcionamento. Talvez os KW tenham melhor acabamento e resistam mais à corrosão. Não que o Weitec seja mau nesse aspecto, mas a Weitec é feita pela KW.
As jantes ficaram impecáveis!
Das Beste oder Nichts.
Patitos
Re: Golf Mk1 GTI
Mensagem por Patitos »
A escolha recaiu nos KW variant 2
Para a semana já cá estáo.
Agora com a ajudinha de um user deste forum, vou adquirir sistema travagem completo do G60, mais direção assistida.
brunituh
Re: Golf Mk1 GTI
Mensagem por brunituh »
estou a gostar de ver amigo ! força nisso..
rui 130
Re: Golf Mk1 GTI
Mensagem por rui 130 »
E fotos dessa evolução, não há? Ou só te tens tempo para o BTT :mrgreen: :mrgreen:
De certeza que isso vai sair de ai um MKI mt acima das nossas espectativas.
Patitos
Re: Golf Mk1 GTI
rui 130 Escreveu:E fotos dessa evolução, não há? Ou só te tens tempo para o BTT :mrgreen: :mrgreen:
É verdade os treinos têm se intensificados.
Neste momento a golf está pronto , faltando colocar os pneus, que após pensar muito recaiu nuns 195/45/15.
Mais uma vez recordo que por opção minha , coloquei o "MEU" golf ao meu gosto pessoal.
Durante esta semana coloco fotos
gti16v
Veículos: Iveco Turbo Daily
Re: Golf Mk1 GTI
Mensagem por gti16v »
Fotos é que é falar :wink: :wink: venham elas :mrgreen: :mrgreen:
GoIII
Re: Golf Mk1 GTI
Mensagem por GoIII »
Também quero ver o resultado final! Até agora só tenho a dizer que tens feito um excelente trabalho!
Fonseca
Re: Golf Mk1 GTI
Mensagem por Fonseca »
Sem dúvida nenhuma que este é um dos carros mais interessantes que andam por aqui... Tou curioso para ver como vai ser o resultado final...
Patitos
Re: Golf Mk1 GTI
O Carro vai agora para a banhoca :D :D :D , atenção que este carro tem 2 corres distintas.......quando está sol é de uma cor, na sombra muda para outra....tipo camaleão :shock: :shock: :shock:
Vou tirar fotos.
Agradeço que não reparem no tabelié..........um dos pintores lembrou-se de inventar :evil: :twisted: :twisted: e pintou algumas partes da cor da carroçaria...tipo tunning :twisted: :twisted:
Até não fica mal....mas não estava á espera
brunituh
Re: Golf Mk1 GTI
Patitos Escreveu:Boas
Vou tirar fotos.
essa parte do tablier é que nao vou muito ha bola com isso amigo :S mas se nao gostares tambem e so trocares por outro.. quais foram as peças pintadas ? as janets ficaram espectaculares :mrgreen: posta mais umas fotos :P
Patitos
Re: Golf Mk1 GTI
Como não podia deixar de ser..........um problemita :!: :!: :!: A cor que escolhi não está em condições....por isso este sabado vai ser pintado de novo ~.
Eu sei que sou esquesito, mas se paguei, tenho que estar bem servido.
Já ouve um colega no forum que viu o carro e até tirou umas fotos, mas não era bem a cor que eu queria, e o proprio pintor admitiu que faltou passar umas camadas de " perola ".
No inicio da proxima semana serão colocadas as respectivas fotos, e uma descrição do material.
Shaggy
Re: Golf Mk1 GTI
Mensagem por Shaggy »
Se não está...pinta de novo ! É isso mesmo !
Este projecto promete...
"Buy Portuguese products and help your economy"
Valpaços
Re: Golf Mk1 GTI
Mensagem por Valpaços »
não sei como deixam entrar num nacionar de rally de clássicos um carro k nem sequer tem esse motor de origem mas ta certo..
VolksWagen Golf Mk2 Gti 16v
Mini Cooper D
