[DIY GERAL] - Canais de adaptaçao Vag-Com
mario_Renato
Mensagem por mario_Renato »
ver aqui q ta formatadinho
http://www.ross-tech.com/vag-com/cars/tdi.html
Special adaptations: Login code 12233:
These procedures do NOT apply to the PD engines!
* To perform the following adaptations (except idle) you need to use the Login function.
* Enter 12233 as a Login code.
* Misuse of some of the adaptations can lead to engine failure.
* This is done at your own risk!
* Note that the EGR setting is for off-road use only...
[Select]
[01 - Engine]
[Login - 11]
Enter 12233 to activate special adaptations,
[Do It!]
[Adaptation - 10]
Enter the "channel number" below to select each channel.
Put in the suggested value(s) in "new value".
[Test]
Observe the "test value" field to make sure the adaptation setting is acceptable.
[Save]
Channel 1: injected quantity
* Check the injected quantity at idle, engine warm and all power consuming devices turned off.
* Specification is 2.5 to 9 mg/h.
* To change the amount of injected fuel perceived by the ECU, go to adaptation channel 1.
* If you have driveability problems, you may want to increase it to 3-4 mg/h.
* For slightly improved throttle response, you may try to decrease the value.
Channel 2: idle speed
* No login required
* The stock adaptation value should be 32768 (corresponds to 903 rpm).
* Increase or decrease this to change idle speed.
Channel 3: EGR
* To decrease the EGR rate, increase the number to the highest possible value (typically 33768).
* This will prevent/slow down the intake manifold clogging problem and reduce smoke.
* Though the MAF at idle is still within specifications (370 mg/h) do not use this adaptation on the road :-)
* Again, this EGR setting is for off-road use only !!!
Channel 4:
* Don’t mess with it!
Channel 5: starting conditions
* Though undocumented, this channel effects the injected quantity the ECU allows when starting.
* You may want to experiment with it as a temporary fix for bad-start problems
Channel 18:
* On some EDC-15 ECUs, this channel has a non-zero value in it like 190.
* Yes, that's the "speed limiter". Don't mess with it!
* It can only be adjusted downward, and it's one-way! You cannot increase the value, and if you decrease it, you're stuck with it.
* So unless you want to permanently decrease your car's top speed, Don't mess with it!
* If you do mess with it and your car ends up with a lower top speed than it had before, don't call us, don't e-mail us, and don't complain that we didn't warn you!
Activating Cruise Control on a new ECU (DBW):
Factory fresh ECU's often come with cruise control de-activated.
[Select]
[01 - Engine]
[Login - 11]
Enter 11463 to activate cruise control
[Do It!]
Installing a new ECU:
Immobilizer 2 info (2000-2001)
Immobilizer 3 info (2002+)
Vovin Tharos
Veículos: Golf MK3 GT
Mensagem por Vovin Tharos »
pois
tens razao!!!
já agora...
o que é isto????? :oops:
Imagem Imagem
mario_Renato
lol...
como desligar a EGR
Activar o cruise control
ajustar o ralenti
DieselPower
Mensagem por DieselPower »
Vovin Tharos Escreveu:pois
tens razao!!!
já agora...
:lol: :lol: :lol:
Vovin Tharos
ahhhh
ok!!!
agora sim!!!
:lol: :lol: :lol:
Imagem Imagem
Law_
Mensagem por Law_ »
impecavel...se eu conseguisse entrar no motor pelo 12233...mas nao estou a conseguir...alguem me diz porque?
variant
Veículos: Alguns...
Mensagem por variant »
AQUI FICA MAIS UMAS COISINHAS EM PORTUGUES :P
"Recalibrar" a EGR
- entrar em Select Control Module
- seleccionar o modulo 01 - Engine
- neste modulo seleccionar Login - 11
- colocamos 12233 e carrega-se em Do it!
- seleccionar Adaptation - 10
- em Channel Number colocar 03 e fazer Read
- deve aparecer na descrição na parte de cima no 2º campo (Mass air / rev) um valor de cerca de 275/280 (era o que estava no meu).
- em New Value deverá estar 32768, vamos colocar 33768 e fazer Test, o valor Mass Air / Rev deve subir para 370/380.
- se tudo correu bem até aqui é só fazer Save e está terminado
Entrar em Instrumentos(17) e Recode(07)
De seguida intruduzir um codigo de acordo com:
00xxx: No available equipment
01xxx: Brakepad wear sensor warning activate
02xxx: Seatbelt warning activate
04xxx: Washer fluid level warning active
16xxx: Navigation
xx1xx: Europe (EU) - Relogio de 24h, contagem em km
xx2xx: USA (US) - Relogio de 12h am/pm, contagem em milhas
xx3xx: Canada (CDN) - Relogio de 12h am/pm, contagem em km
xx4xx: Great Britain (GB) - Relogio de 24h, contagem em milhas
xx5xx: Japan (JP)
xx6xx: Saudi Arabia (SA)
xx7xx: Australia (AUS)
xxx0x: Vehicles w. fixed service intervals wo. oil/temp. sender
xxx1x: Vehicles w. flexible service intervals w. oil/temp. sender
xxx2x: Vehicles w. fixed service intervals w. oil/temp. sender
xxx3x: No service interval
xxx4x: 4-cylinder
xxx5x: 5-cylinder
xxx6x: 6-cylinder
xxxx1: 4345 (Distance impulse multiplier)
xxxx2: 3528 (Distance impulse multiplier)
xxxx3: 4134 (Distance impulse multiplier)
xxxx4: 3648 (Distance impulse multiplier)
Para combinacoes basta somar os valores.
Exemplo: 07xxx corresponde a 01 + 02 + 04 activar os avisos de desgaste das
pastilhas dos travoes, o aviso do cinto de segurança e o aviso
de pouco liquido de limpeza do parabrisas.
Se o carro possuir destrancar selectivo, ao pressionar uma vez 'destrancar' no comando
vai abrir a porta do condutor e duas vezes vai abrir todas as portas.
Para fazer todas as portas destrancar de uma vez só, subtrair 1 ao valor existente.
[Select]
[46 - Cent. Conv.] (35 - Cent. Locking para carros com vidros manuais)
[Recode - 07]
Software Coding: 0000x
Anotar o 'Software Coding' existente para referencia futura.-------04097
Alterar o ultimo digito (x) deste valor de 5-digitos de acordo com:
x + 1: Abertura da porta do condutor ao premir uma vez, todas ao premir duas vezes.
x - 1: Abertura de todas as portas ao premir uma vez.
[Do It!]
Assim, num carro que esta programado para destrancar selectivo (00259) subtrai-se 1 para ficar (00258)
de modo que todas as portas destrancam ao premir uma vez no comando.
[Select]
[46 - Cent. Conv.]
[Adaptation - 10]
Channel 03 Trancar aos 20km/h
Channel 04 Destrancar ao retirar a chave da ignicao
Channel 05 Apitar ao destrancar c/ comando
Channel 06 Apitar ao trancar c/ comando
Channel 07 Piscas ao destrancar c/ comando
Channel 08 Piscas ao trancar c/ comando
Valor (1 = ligar, 0 = desligar)
[Save]
Mudar Linguagem do Computador de Bordo:
[Select]
[17 - Instruments]
[Adaptation - 10]
Channel Number: 04
[Read]
As linguagens disponiveis sao:
00001 - Alemao
00002 - Ingles
00003 - Frances
00004 - Italiano
00005 - Espanhol
00006 - Portugues
[Save]
Vw Bora Pd 115
Vw Golf mk2 GTD
Vw Polo 6N
Smart Roadster F1
Renault Clio S DCi
ADOLFO DIAS
Mensagem por ADOLFO DIAS »
Belo DIY :wink:
Mas julgo ke ja ha por aki esta informaçao,,,, 8)
Mas procurem melhor no site da ROSS-TECH, pois nem sempre o codigo 12233 funciona :wink:
volksharan
Re: [DIY GERAL] - Canais de adaptaçao Vag-Com
Mensagem por volksharan »
Boa noite Pessoal,
Alguem sabe se todos os golf 4 têm o módulo 46 disponivel para aceder pelo VAG COM?
Não consigo aceder ao modificação 46 nem modificação 9 no meu golf 4 de 2002 motor ATD e confortline...
Queria por o golf a trancar portas aos 15/20 km's mas sem aceder ao módulo a coisa não está fácil :(
Haverá alguem que me me ilumine pf :D
Desde já obrigado
Volksharan
willianmulher
Veículos: Golf GTI 1.8 20v 2000
Mensagem por willianmulher »
pessoal nao consigo fazer o LOGIN na ENGINE com o código 12233 e nem ativar o Cruise control
golf MK4 1.8 150 cv se alguém poder ajudar
