Turbo nas couves? vacuo? P0234
nakatafernandes
Re: Turbo nas couves? vacuo? P0234
Mensagem por nakatafernandes »
boas, entretando posso deixar ca diagnostico vcds. A EGR ainda nao foi desativada eletronicamente. Posso vos adiantar que carro está com um consumo anormal digo eu de 11l/100km. E a consumir cerca de 1 litro oleo a cada 1000kms. :x
antes de o comprar foi visto por mecanico... mas de nada valeu a pena...
Friday,25,June,2021,13:38:41:60804
VCDS Version: Release 10.6.0
Data version: 20100630
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56 62 72 76 77
VIN: WVGZZZ1TZ4W174812 Mileage: 219200km/136204miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 1010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 EH HW: 028 101 178 6
Component: R4 2,0L EDC G000SG 5687
Revision: 12345678 Serial number: VWZ7Z0D9720913
Coding: 0000072
Shop #: WSC 80093 222 69422
VCID: 6DDA4C420DF9
1 Fault Found:
16785 - EGR System: Insufficient Flow
P0401 - 000 - -
Freeze Frame:
RPM: 1638 /min
Torque: 64.0 Nm
Speed: 39.0 km/h
Load: 20.0 %
Duty Cycle: 14.7 %
Bin. Bits: 00001000
Mass Air / Rev.: 290.0 mg/str
Mass Air / Rev.: 620.0 mg/str
Readiness: 0 0 0 0 1
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0103
Coding: 0023238
Shop #: WSC 01324 785 00200
VCID: 3A70B71E0C37
No fault code found.
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1K0 907 044 L
Component: ClimatronicPQ35 061 0201
Shop #: WSC 00000 000 00000
VCID: 30649536DA4B
1 Fault Found:
01809 - Actuating Motor for Temperature Flap; Left (V158)
000 - -
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 T HW: 1K0 937 049 T*
Component: Bordnetz-SG 1.0 H30 0704
Revision: 00030000 Serial number: 00000000772002
Coding: 01898F020004200000120C000000000000
VCID: 4084C5F66AEB
Part No: 1T0 955 119 C
Component: Wischer VW358 012 0401
Coding: 00065493
Shop #: WSC 00000
2 Faults Found:
01064 - Terminal 58d; Interior Dimming
012 - Electrical Fault in Circuit
01330 - Central Control Module for Central Convenience (J393)
004 - No Signal/Communication - Intermittent
Address 15: Airbags Labels: 1T0-909-605.lbl
Part No SW: 1T0 909 605 B HW: 1T0 909 605 B
Component: 02 AIRBAG VW62 0506 1400
Revision: 07023000 Serial number: 0037SD07BYBS
Coding: 0012338
VCID: 346C99262E53
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
Component: Lenksäulenmodul 012 0030
Coding: 0000042
VCID: 30649536DA4B
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1T0 920 860 G
Component: KOMBIINSTRUMENT VDD 3354
Coding: 0003101
VCID: 356AA4222529
Address 18: Aux. Heat Labels: None
Part No: 1K0 815 071 K
Component: Zuheizer 031 1009
Revision: C Serial number: 09008374
Coding: 0000011
VCID: 2D5A8C42CD79
4 Faults Found:
00003 - Control Module
014 - Defective - Intermittent
Freeze Frame:
01320 - Control Module for Climatronic (J255)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 4
Reset counter: 138
Mileage: 151167 km
Time Indication: 0
Date: 2000.00.00
Time: 01:52:33
01415 - Recirculating Pump (V55)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 0
Reset counter: 55
Mileage: 167009 km
Time Indication: 0
Date: 2000.00.00
Time: 15:24:25
Freeze Frame:
OFF
Temperature: 65.0°C
Temperature: 75.0°C
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Priority: 0
Reset counter: 55
Mileage: 167009 km
Time Indication: 0
Date: 2000.00.00
Time: 15:24:25
Freeze Frame:
OFF
Temperature: 65.0°C
Temperature: 75.0°C
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 C HW: 1K0 907 951
Component: Gateway H08 0080
Coding: 3D3F17C0078002
VCID: 27567E6AEF85
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Component: IMMO 3354
VCID: 356AA4222529
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
Part No: 1T0 959 701
Component: Tuersteuergeraet 09 0127
Coding: 0000116
VCID: F4ECD926EED3
1 Fault Found:
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
VCID: 32609F3ED447
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 T
Component: 01 KSG 0560
Coding: 80E802087F2D8505484FC65001
VCID: 4182C0F261E1
Part No: 1T0 951 172 C
Component: Innenraumueberw.009 4808
Coding: 00000000
Shop #: WSC 00000
Part No: 1K0 951 605 A
Component: LIN BACKUP HORN H01 1201
Part No: 1K0 907 719
Component: Neigungssensor 003 0003
1 Fault Found:
01134 - Alarm Horn (H12)
000 - -
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
Part No: 1T0 959 702
Coding: 0000116
VCID: F5EAE422E5A9
2 Faults Found:
00944 - Heated Exterior Mirror; Passenger Side (Z5)
012 - Electrical Fault in Circuit - Intermittent
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1K0 035 186 J
Component: Radio BNO 0016
Coding: 0042400
VCID: 2D5A8C42CD79
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN1.lbl
Part No: 1K0 959 703 B
Component: Tuersteuergeraet 06 0214
Coding: 0000048
VCID: 2F66964AC775
1 Fault Found:
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN1.lbl
Part No: 1K0 959 704 B
Coding: 0000048
VCID: 30649536DA4B
1 Fault Found:
Address 76: Park Assist Labels: 1K0-919-283.lbl
Part No: 1K0 919 283 A
Component: 02 Einparkhilfe 0101
VCID: 2D5A8C42CD79
Address 77: Telephone Labels: Redir Fail!
Part No: 1K0 035 729 B
Component: CIB PAH HW 112 SW 0194
Shop #: WSC 00001 000 00000
VCID: 28547D56E29B
End ---------------------------------------------------------------------
nakatafernandes Escreveu: 12 out 2021, 13:03 boas, entretando posso deixar ca diagnostico vcds. A EGR ainda nao foi desativada eletronicamente. Posso vos adiantar que carro está com um consumo anormal digo eu de 11l/100km. E a consumir cerca de 1 litro oleo a cada 1000kms. :x
Chassis Type: 1K0
Scan:
Coding: 0000072
VCID: 6DDA4C420DF9
1 Fault Found:
P0401 - 000 - -
Freeze Frame:
RPM: 1638 /min
Torque: 64.0 Nm
Speed: 39.0 km/h
Load: 20.0 %
Duty Cycle: 14.7 %
Bin. Bits: 00001000
O mecânico consegue ver muita coisa se for experiente nesses modelos, mas há coisas que só com testes específicos consegue(€€€).
Se tens esse consumo de óleo anormal, supondo que não há fugas e o nível está a ser verificado corretamente, é mais uma vez provável que o culpado seja o turbo.
Em relação á egr, ela está bloqueada mas não desativada na ecu? É que se for esse o caso, nesse carro em particular, não vais conseguir fazer nenhum dos testes que recomendei corretamente pois vai dar valores irregularidades do sensor de massa de ar e turbo, a ecu vai estar sempre a tentar corrigir isso e é impossível.
Caso a egr esteja ligada, tens definitivamente aí um problema relacionado com vácuo, a egr não está a abrir, o que aponta novamente para a unidade de vácuo.
Nesse erro que está aí com 20% de tps os valores não estão ok.
