Golf 6 1.6Tdi sem direção apos a substituição da bateria
Deykill
Veículos: Volkswagen Golf 6 MK5 1.6tdi 105cv
Mensagem por Deykill »
Boa tarde a todos.
Venho aqui pedir a vossa ajuda no seguinte:
A viatura em questão é um Golf VI 1.6TDI 105Cv, 2009 confortline, com cerca de 220 000km
Verifiquei os fuziveis todos e parece estar tudo ok
Alguem podia me ajudar com estes erros?
Seque os anexos dos erros
Diagnóstico
Chassis Type: 1K0
Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 52 56 62 72 77
VIN: WVWZZZ1KZAP094867
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CAYC) Labels: None
Part No SW: 03L 997 557 M HW: 03L 906 023 A
Component: R4 1.6l TDI H23 9983
Revision: --H23--- Serial number: 00000000000000
Coding: 00114016032400080000
Shop #: WSC 00028 028 00024
ASAM Dataset: EV_ECM16TDI02103L 003003
ROD: N/A
VCID: 468948C1F9BCCC9
No ASAM data for: "EV_ECM16TDI02103L" (VW36)
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 113B200D092B00FE881304EA90200040300000
Shop #: WSC 00028 028 00001
VCID: 78F5F639CBC86A9
1 Fault Found:
01486 - System Function Test Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 48
Mileage: 230283 km
Time Indication: 0
Date: 2127.14.31
Time: 00:29:51
Freeze Frame:
Count: 3
Count: 2
Count: 29184
Count: 320
Count: 50176
Count: 0
Count: 256
Count: 0
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 BT HW: 5K0 907 044 BT
Component: Climatronic H15 0709
Revision: 00003001
Coding: 0000000002
ASAM Dataset: EV_Climatronic A01006
ROD: EV_Climatronic_VW36.rod
VCID: 7EF9E021E1EC549
1 Fault Found:
9481988 - Air Quality Sensor
B10AF 04 [009] - Internal System Fault
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 48
Mileage: 230283 km
Date: 2127.14.31
Time: 00:30:02
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 086 C HW: 1K0 937 086 C
Component: BCM PQ35 M 103 0573
Revision: 00103 AF
Coding: 40180A3A98251AC040080080740081E443510088736D8560648000200000
VCID: 30650E196338729
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 09110 21 0512
Coding: 009795
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 191109 05 54 0402
Coding: 0330AD
Address 10: Park/Steer Assist (J446) Labels: 3C8-919-475.clb
Part No SW: 5K0 919 475 C HW: 5K0 919 475
Component: PARKHILFE 8K H07 0008
Revision: -------- Serial number: 12990931507997
Coding: 100001
VCID: 36693801815C5C9
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5K0 959 655 D HW: 5K0 959 655 D
Component: AirbagVW10 037 0606
Serial number: 003FKD0373CX
Coding: 00003132
ASAM Dataset: EV_AirbaVW10SMEVW360 A01011
ROD: EV_AirbaVW10SMEVW360_VW36.rod
VCID: 3B7F2935B27E811
Crash sensor for side airbag; driver side:
Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME1048114EZZZQ
Crash sensor for side airbag; passenger side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME5930614DZZZZ
Crash sensor for side airbag; rear driver side:
Component: S.Sens.Fahr.H --- ----
Serial number: 3512QSME22494122ZZZH
Crash sensor for side airbag; rear passenger side:
Component: S.Sens.Beif.H --- ----
Serial number: 3522QSME06434235ZZZJ
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CF HW: 1K0 953 549 CF
Component: J0527 056 0111
Coding: 0000732
VCID: 78F5F6390BC86A9
Subsystem 1 - Part No: 3C8 959 537 D
Component: E221__MFL-TK6 H06 0022
Coding: 00000226
Shop #: WSC 00000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5K0 920 870 G HW: 5K0 920 870 G
Component: KOMBI H03 0305
Coding: 170F00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
VCID: 31630B1D60327B1
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0111
Revision: H07 01 Serial number: 141109F2001396
Coding: E9A07F06400602000002
VCID: 69D3A37D4062C31
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 0305
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
VCID: EAD15C710D64489
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 D HW: 1T0 035 680 C
Component: RNS-MID H04 4020
Revision: AB001001 Serial number: VWZ6Z7J6321011
Coding: 04000402040000800000
ASAM Dataset: ------------------------- ------
VCID: 2F670D657E066D1
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 5K0 959 701 D HW: 5K0 959 701 D
Component: Tuer-SG 009 2139
Coding: 0000180
VCID: 336F0115522E491
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 69 3001
Revision: 00H17000
VCID: 31630B1DA8327B1
2 Faults Found:
02614 - Steering Box
014 - Defective - MIL ON
Freeze Frame:
Fault Status: 11101110
Fault Priority: 6
Fault Frequency: 1
Time Indication: 0
Freeze Frame:
Voltage: 10.75 V
DD
Temperature: 22.0°C
Speed: 0.0 km/h
Torque: -0.2 Nm
Torque: 0.000 Nm
Term 15 On
03803 - Steering Angle Sensor for Steering Aid
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Mileage: 230283 km
Time Indication: 0
Date: 2127.14.31
Time: 00:31:46
Freeze Frame:
Battery Volts: 0.7 V
ER
Temperature: 25.0°C
Count: 2
Steering Angle: 0.00°
Count: 1
SteerAng n.Init
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 5K0 959 702 E HW: 5K0 959 702 E
Coding: 0000436
VCID: 356B3F0D5C5A571
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 5K0 959 703 C HW: 5K0 959 703 C
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 00028 028 1012545
VCID: 346D020957204E9
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 5K0 959 704 C HW: 5K0 959 704 C
Coding: 0000144
Address 77: Telephone (J412) Labels: None
Part No SW: 3C8 035 730 C HW: 3C8 035 730 C
Component: Telefon 012 0822
Revision: -------- Serial number: 35909603512821
Coding: 060004000100011100000000
Shop #: WSC 62433 001 1048576
ASAM Dataset: EV_UHVPremi A02705
ROD: EV_UHVPremi_VW36.rod
VCID: 234FF1552ACED91
End ----------------------------------------
Anexos
DeyColioo
Re: Golf 6 1.6Tdi sem direção apos a substituição da bateria
Há 2 situações comuns, uma, apenas não fizeste reset, e tal como diz aí, está em modo de aprendizagem( test mode) só precisas de ir dar uma volta e deverá ficar ok, ou com o carro parado no sítio ligado, virar a direção totalmente para cada lado, a outra situação, é se mesmo depois disso não ficar ok, há um cabo que fornece energia á direção que costuma dar problemas, e geralmente o problema aparece precisamente numa situação como a tua, quando o pessoal mexe na bateria.
Uma outra coisa importante que pode não ter necessariamente a ver com o teu caso, verificar sempre se o alternador esta ok quando uma bateria vai á vida, muitas vezes a bateria vai-se porque o alternador esta ko, o alternador não é um carregador de baterias....., quando está mau não produz carga suficiente e a bateria acaba sempre por sofrer.
Deykill
Mario_Marques Escreveu: 29 abr 2021, 23:25 Há 2 situações comuns, uma, apenas não fizeste reset, e tal como diz aí, está em modo de aprendizagem( test mode) só precisas de ir dar uma volta e deverá ficar ok, ou com o carro parado no sítio ligado, virar a direção totalmente para cada lado, a outra situação, é se mesmo depois disso não ficar ok, há um cabo que fornece energia á direção que costuma dar problemas, e geralmente o problema aparece precisamente numa situação como a tua, quando o pessoal mexe na bateria.
Boa tarde ja tentei fazer o resetandei cerca de 5 km mas nao ficou ok agora tenho que verificar este cabo que fornece energia a direção
Podia me diser a localização de este cabo
DeyColioo
Deykill
Atualização
Bom dia depois de estar parado 2 semanas descaregou a nova bateria
DeyColioo
cristo_844
Veículos: GOLF V
Mensagem por cristo_844 »
Antes de mais apaga os erros e faz um novo auto-scan com a bateria carregada e com uma versao do vcds mais recente!
Deykill
cristo_844 Escreveu: 04 mai 2021, 00:16 Antes de mais apaga os erros e faz um novo auto-scan com a bateria carregada e com uma versao do vcds mais recente!
Boa noite fiz um auto scan com uma interface mais recente e depois apaguei os erros e ficaram assim mas parece que tenho um curt circuito ou um sinal a baixo do permitido no primeiro scan
Sexta-feira,07,Maio,2021,19:00:48:00009
VCDS -- Emulador de VAG/VAS baseado em Windows Correndo em Windows 10 x64
Versão do VCDS: PTT 20.12.0.3
Versão de Dados: 20210130 DS322.1
www.vag-com-portugues.com
VIN: WVWZZZ1KZAP094867 Placa Identificação:
Quilometragem: 230290km Ordem de Trabalho:
Tipo de Chassi 1K0)
Consultar as UCEs 01 03 08 09 10 15 16 17 19 25 37 42 44 46 52 56 62 72 77
VIN: WVWZZZ1KZAP094867 Quilometragem: 230290km
01-Motor -- Estado: Correto 0000
03-Freios (Travões) -- Estado: Avaria 0010
04-Angulo direção -- Estado: Correto 0000
08-Ar condicionado -- Estado: Avaria 0010
09-Central elétrica -- Estado: Avaria 0010
10-Assist. Estacion. -- Estado: Correto 0000
15-Airbags -- Estado: Correto 0000
16-Volante -- Estado: Avaria 0010
17-Instrumentos -- Estado: Correto 0000
19-Gateway CAN -- Estado: Correto 0000
25-Imobilizador -- Estado: Correto 0000
37-Navegação -- Estado: Avaria 0010
42-Porta Motorista -- Estado: Correto 0000
44-Direção assistida -- Estado: Avaria 0010
46-Conforto -- Estado: Correto 0000
52-Porta Passageiro -- Estado: Avaria 0010
56-Radio -- Estado: Avaria 0010
62-Porta tras. esq. -- Estado: Correto 0000
72-Porta tras. dir. -- Estado: Correto 0000
77-Telefone -- Estado: Avaria 0010
Endereço 01: Motor (J623-CAYC) Etiquetas:. PTT\03L-906-023-CAY.clb
N° de Peça SW: 03L 997 557 M HW: 03L 906 023 A
Componente: R4 1.6l TDI H23 9983
Versão: --H23--- N° de Serie: 00000000000000
Codificação: 00114016032400080000
Nº Oficina: WSC 00028 028 00024
Dados ASAM: EV_ECM16TDI02103L997557M 003003
ROD: EV_ECM16TDI02103L997557L.rod
VCID: 4683E31FF9A7E4B47A-8012
Nenhuma avaria detectada.
Readiness: 0 0 0 0 0
Endereço 03: Freios (Travões) (J104) Etiquetas:. PTT\1K0-907-379-60EC1F.clb
N° de Peça SW: 1K0 907 379 AH HW: 1K0 907 379 AH
Componente: ESP MK60EC1 H30 0107
Versão: 00H30001
Codificação: 113B200D092B00FE881304EA90200040300000
Nº Oficina: WSC 00028 028 00001
VCID: 78FF5DE7CBD3424438-802C
2 Avarias detectadas:
01487 - Teste de funcionamento do sistema
000 - - - Esporádico/a/s
Quadro Congelado:
Estado de Avaria: 00100000
Prioridade de Avaria: 2
Freqüência de Avaria: 2
Resets do Contador: 49
Quilometragem: 230284 km
Indicação de Tempo: 0
Data: 2015.09.28
Tempo: 02:11:23
Quadro Congelado:
Conta: 0
Conta: 0
Conta: 12800
Conta: 321
Conta: 50705
Conta: 10307
Conta: 7168
Conta: 0
01486 - Ativado o teste de funcionamento do sistema
000 - -
Quadro Congelado:
Estado de Avaria: 01100000
Freqüência de Avaria: 1
Quilometragem: 230283 km
Data: 2015.09.28
Tempo: 00:36:23
Quadro Congelado:
Conta: 3
Conta: 2
Conta: 29184
Conta: 320
Conta: 50688
Conta: 0
Conta: 256
Conta: 0
Endereço 08: Ar condicionado (J255) Etiquetas:| PTT\5K0-907-044.clb
N° de Peça SW: 5K0 907 044 BT HW: 5K0 907 044 BT
Componente: Climatronic H15 0709
Versão: 00003001
Codificação: 0000000002
Dados ASAM: EV_Climatronic A01006
ROD: EV_ClimaAutoBasis_VW36.rod
VCID: 7EF34BFFE1F77C7472-802A
1 Avaria detectada:
9481988 - Sensor de qualidade do ar
B10AF 04 [009] - Defeituoso/a(s)
Confirmado - Verificado desde o Apagamento da Memória
Quadro Congelado:
Estado de Avaria: 00000001
Prioridade de Avaria: 3
Freqüência de Avaria: 18
Data: 2021.05.07
Tempo: 00:30:02
Endereço 09: Central elétrica (J519) Etiquetas:. PTT\1K0-937-08x-09.clb
N° de Peça SW: 1K0 937 086 C HW: 1K0 937 086 C
Componente: BCM PQ35 M 103 0573
Versão: 00103 AF
Codificação: 40180A3A98251AC040080080740081E443510088736D8560648000200000
VCID: 306FA5C763235A04B0-8064
Subsistema 1 - N° de Peça: 1K1 955 119 F Etiquetas: PTT\1KX-955-119.CLB
Componente: Wischer 09110 21 0512
Codificação: 009795
Subsistema 2 - N° de Peça: 1K0 955 559 AH Etiquetas: PTT\1K0-955-559-AG.CLB
Componente: RLS 191109 05 54 0402
Codificação: 0330AD
4 Avarias detectadas:
02391 - Borne 30 referência
011 - Interrupção - Esporádico/a/s
Quadro Congelado:
Estado de Avaria: 00101011
Prioridade de Avaria: 4
Resets do Contador: 89
Quilometragem: 230288 km
Quadro Congelado:
Borne 15 OFF
Tensão: 12.30 V
Desligado
ligado
Borne 50 OFF
Desligado
Desligado
00446 - Limitação de função devida à baixa voltagem
002 - valor-limite inferior não foi atingido - Esporádico/a/s
Quadro Congelado:
Estado de Avaria: 00100010
Prioridade de Avaria: 6
Freqüência de Avaria: 3
Quilometragem: 230289 km
Data: 2015.09.28
Tempo: 02:41:57
Quadro Congelado:
Borne 15 OFF
Tensão: 9.80 V
Desligado
Desligado
Borne 50 OFF
Desligado
Desligado
01520 - Sensor de luz e chuva (G397)
Quadro Congelado:
Quadro Congelado:
Borne 15 OFF
Tensão: 9.15 V
Desligado
Desligado
Borne 50 OFF
Desligado
Desligado
00153 - Motor do limpador de vidros do lado do motorista (V216)
Quadro Congelado:
Data: 2015.09.28
Tempo: 13:38:33
Quadro Congelado:
Borne 15 ON
Tensão: 6.70 V
ligado
Desligado
Borne 50 OFF
Desligado
Desligado
Endereço 10: Assist. Estacion. (J446) Etiquetas:. PTT\3C8-919-475.clb
N° de Peça SW: 5K0 919 475 C HW: 5K0 919 475
Componente: PARKHILFE 8K H07 0008
Versão: -------- N° de Serie: 12990931507997
Codificação: 100001
VCID: 366393DF81477434EA-8062
Endereço 15: Airbags (J234) Etiquetas:| PTT\5K0-959-655.clb
N° de Peça SW: 5K0 959 655 D HW: 5K0 959 655 D
Componente: AirbagVW10 037 0606
N° de Serie: 003FKD0373CX
Codificação: 00003132
Dados ASAM: EV_AirbaVW10SMEVW360 A01011
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3B7582EBB265A95C15-806E
Sensor de colisão do airbag lateral: lado do condutor:
Subsistema 1 - N° de Peça SW: 5K0 959 354 HW: 5K0 959 354
Componente: S.Sens.Fahr.V H01 ----
N° de Serie: 3572MSME1048114EZZZQ
Sensor de colisão do airbag lateral: lado do passageiro:
Subsistema 2 - N° de Peça SW: 5K0 959 354 HW: 5K0 959 354
Componente: S.Sens.Beif.V H01 ----
N° de Serie: 3582MSME5930614DZZZZ
Sensor de colisão do airbag lateral traseiro: lado do condutor:
Componente: S.Sens.Fahr.H --- ----
N° de Serie: 3512QSME22494122ZZZH
Sensor de colisão do airbag lateral traseiro no lado do passageiro:
Componente: S.Sens.Beif.H --- ----
N° de Serie: 3522QSME06434235ZZZJ
Endereço 16: Volante Etiquetas: PTT\1K0-953-549-MY9.clb
N° de Peça SW: 1K0 953 549 CF HW: 1K0 953 549 CF
Componente: J0527 056 0111
Codificação: 0000732
VCID: 78FF5DE70BD3424438-802C
Subsistema 1 - N° de Peça: 3C8 959 537 D Etiquetas: PTT\3C8-959-537.CLB
Componente: E221__MFL-TK6 H06 0022
Codificação: 00000226
Nº Oficina: WSC 00000
1 Avaria detectada:
01426 - Painel de controle do volante (E221)
004 - sem sinal/comunicação - Esporádico/a/s
Endereço 17: Instrumentos (J285) Etiquetas:| PTT\5K0-920-xxx-17.clb-SRI1
N° de Peça SW: 5K0 920 870 G HW: 5K0 920 870 G
Componente: KOMBI H03 0305
Codificação: 170F00
Dados ASAM: EV_Kombi_UDS_VDD_RM09 A04052
ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
VCID: 3169A0C36029530CBF-8064
Endereço 19: Gateway CAN Etiquetas:. PTT\1K0-907-530-V4.clb
N° de Peça SW: 1K0 907 530 AD HW: 1K0 907 951
Componente: J533 Gateway H07 0111
Versão: H07 01 N° de Serie: 141109F2001396
Codificação: E9A07F06400602000002
VCID: 69D908A34079EBCCB7-803C
Endereço 25: Imobilizador (J334) Etiquetas:| PTT\5K0-920-xxx-25.clb
N° de Peça SW: 5K0 953 234 HW: 5K0 953 234
Componente: IMMO H03 0305
N° de Serie:
Codificação: 000000
Nº Oficina: WSC 00000 000 00000
Dados ASAM: EV_Immo_UDS_VDD_RM09 A03005
ROD: EV_Immo_UDS_VDD_RM09_VW23.rod
VCID: 6ADB77AF8D7FE0D4BE-803E
Endereço 37: Navegação (J0506) Etiquetas:. PTT\1T0-035-680.clb
N° de Peça SW: 1T0 035 680 D HW: 1T0 035 680 C
Componente: RNS-MID H04 4020
Versão: AB001001 N° de Serie: VWZ6Z7J6321011
Codificação: 04000402040000800000
VCID: 2F6DA6BB7E1D45FCA9-807A
00532 - Voltagem de alimentação
Quadro Congelado:
Prioridade de Avaria: 5
Data: 2015.09.28
Tempo: 21:19:08
Quadro Congelado:
Data: 2015.09.28
Tempo: 21:18:59
Endereço 42: Porta Motorista Etiquetas:. PTT\1K0-959-701-MIN3.clb
N° de Peça SW: 5K0 959 701 D HW: 5K0 959 701 D
Componente: Tuer-SG 009 2139
Codificação: 0000180
VCID: 3365AACB5235611CCD-8066
Endereço 44: Direção assistida Etiquetas: PTT\1K0-909-14x-GEN3.clb
N° de Peça: 1K0 909 144 J
Componente: EPS_ZFLS Kl. 69 3001
Versão: 00H17000
VCID: 3169A0C3A829530CBF-8064
1 Avaria detectada:
02614 - Caixa de direção
014 - com defeito - Luz de Avarias ligada
Quadro Congelado:
Estado de Avaria: 11101110
Resets do Contador: 255
Quadro Congelado:
Tensão: 10.75 V
DD
Temperatura: 22.0°C
Velocidade: 0.0 km/h
Torque: -0.2 Nm
Torque: 0.000 Nm
Borne 15 ON
Endereço 52: Porta Passageiro Etiquetas:. PTT\1K0-959-702-MAX3.clb
N° de Peça SW: 5K0 959 702 E HW: 5K0 959 702 E
Codificação: 0000436
VCID: 356194D35C417F2CE3-8060
1 Avaria detectada:
00110 - Luz do pisca-pisca integrado ao retrovisor externo do lado do passageiro (L132)
012 - Avaria no circuito elétrico
Endereço 56: Radio (J0506) Etiquetas:. PTT\1T0-035-680.clb
Quadro Congelado:
Data: 2015.09.28
Tempo: 21:19:08
Quadro Congelado:
Data: 2015.09.28
Tempo: 21:18:59
Endereço 62: Porta tras. esq. Etiquetas:. PTT\1K0-959-703-GEN3.clb
N° de Peça SW: 5K0 959 703 C HW: 5K0 959 703 C
Componente: Tuer-SG 007 2101
Codificação: 0000144
Nº Oficina: WSC 00028 028 1012545
VCID: 3467A9D7573B6624D4-8060
Endereço 72: Porta tras. dir. Etiquetas:. PTT\1K0-959-704-GEN3.clb
N° de Peça SW: 5K0 959 704 C HW: 5K0 959 704 C
Endereço 77: Telefone (J412) Etiquetas:| PTT\3C8-035-730-A.clb
N° de Peça SW: 3C8 035 730 C HW: 3C8 035 730 C
Componente: Telefon 012 0822
Versão: -------- N° de Serie: 35909603512821
Codificação: 060004000100011100000000
Nº Oficina: WSC 62433 001 1048576
Dados ASAM: EV_UHVPremi A02705
ROD: EV_UHVPremi_A02.rod
VCID: 23455A8B2AD5F19C3D-8076
1 Avaria detectada:
13893632 - Limitação de função por subvoltagem
U1400 00 [008] - -
Esporádico/a/s - Confirmado - Verificado desde o Apagamento da Memória
Quadro Congelado:
Freqüência de Avaria: 10
Quilometragem: 230285 km
Data: 2021.05.07
Tempo: 00:01:32
Fim----------------------(Tempo transcorrido: 02:45)-
DeyColioo
Deykill
Depois de este auto scan apaguei os erros e fiz outro scan e deu isso
Tipo de Chassi 1K0)
09-Central elétrica -- Estado: Correto 0000
16-Volante -- Estado: Correto 0000
37-Navegação -- Estado: Correto 0000
52-Porta Passageiro -- Estado: Correto 0000
56-Radio -- Estado: Correto 0000
77-Telefone -- Estado: Correto 0000
Versão: 00H30001
Quadro Congelado:
Data: 2015.09.28
Tempo: 02:11:23
Quadro Congelado:
Conta: 0
Conta: 0
Conta: 12800
Conta: 321
Conta: 50705
Conta: 10307
Conta: 7168
Conta: 0
000 - -
Quadro Congelado:
Data: 2015.09.28
Tempo: 00:36:23
Quadro Congelado:
Conta: 3
Conta: 2
Conta: 29184
Conta: 320
Conta: 50688
Conta: 0
Conta: 256
Conta: 0
Versão: 00003001
1 Avaria detectada:
B10AF 04 [008] - Defeituoso/a(s)
Quadro Congelado:
Quilometragem: 230290 km
Data: 2021.05.07
Tempo: 12:07:59
Versão: 00103 AF
Codificação: 009795
Codificação: 0330AD
Codificação: 100001
Codificação: 170F00
N° de Serie:
Codificação: 000000
Versão: 00H17000
1 Avaria detectada:
Quadro Congelado:
Data: 2015.09.28
Tempo: 12:09:26
Quadro Congelado:
Tensão: 12.50 V
DD
Temperatura: 22.0°C
Torque: 3.8 Nm
Torque: 0.000 Nm
Borne 15 ON
DeyColioo
cristo_844
Veículos: GOLF V
Versão: 00H30001
Quadro Congelado:
Data: 2015.09.28
Tempo: 02:11:23
Quadro Congelado:
Conta: 0
Conta: 0
Conta: 12800
Conta: 321
Conta: 50705
Conta: 10307
Conta: 7168
Conta: 0
000 - -
Quadro Congelado:
Data: 2015.09.28
Tempo: 00:36:23
Quadro Congelado:
Conta: 3
Conta: 2
Conta: 29184
Conta: 320
Conta: 50688
Conta: 0
Conta: 256
Conta: 0
Soluçao
https://www.youtube.com/watch?v=7AVPRj2BNuc
Versão: 00H17000
1 Avaria detectada:
Quadro Congelado:
Data: 2015.09.28
Tempo: 12:09:26
Quadro Congelado:
Tensão: 12.50 V
DD
Temperatura: 22.0°C
Torque: 3.8 Nm
Torque: 0.000 Nm
Borne 15 ON
Grande possibilidade de a direcção assistida ter ido a vida!
sflopes
Mensagem por sflopes »
Em Golf v tive que substituir caixa direcção,nunca fiquei sem DA, mas a luz no quadrante ora acendia ora apagada,resultado o sensor que fica dentro da caixa avariou.
Deykill
cristo_844 Escreveu: 07 mai 2021, 20:27
Versão: 00H30001
Quadro Congelado:
Data: 2015.09.28
Tempo: 02:11:23
Quadro Congelado:
Conta: 0
Conta: 0
Conta: 12800
Conta: 321
Conta: 50705
Conta: 10307
Conta: 7168
Conta: 0
000 - -
Quadro Congelado:
Data: 2015.09.28
Tempo: 00:36:23
Quadro Congelado:
Conta: 3
Conta: 2
Conta: 29184
Conta: 320
Conta: 50688
Conta: 0
Conta: 256
Conta: 0
Soluçao
Versão: 00H17000
1 Avaria detectada:
Quadro Congelado:
Data: 2015.09.28
Tempo: 12:09:26
Quadro Congelado:
Tensão: 12.50 V
DD
Temperatura: 22.0°C
Torque: 3.8 Nm
Torque: 0.000 Nm
Borne 15 ON
Boa tarde e como podia testar a direção assistida para confirmar a avaria ?
DeyColioo
Deykill
Boa noite acabei de verificar se a ficha de alimentação da bomba de direção tem sinal e sim com o motor parado tem 12.15 v e com o motor a trabalhear tem 14.15v agora a alguma forma de testar esta bomba da direção? E se mandar vir a bomba sem o rack a montagem da mesma e posivel? Ou tem que ser o rack e a bomba ?
DeyColioo
Deykill
Versão: 00H30001
Quadro Congelado:
Data: 2015.09.28
Tempo: 02:11:23
Quadro Congelado:
Conta: 0
Conta: 0
Conta: 12800
Conta: 321
Conta: 50705
Conta: 10307
Conta: 7168
Conta: 0
000 - -
Quadro Congelado:
Data: 2015.09.28
Tempo: 00:36:23
Quadro Congelado:
Conta: 3
Conta: 2
Conta: 29184
Conta: 320
Conta: 50688
Conta: 0
Conta: 256
Conta: 0
Soluçao
Versão: 00H17000
1 Avaria detectada:
Quadro Congelado:
Data: 2015.09.28
Tempo: 12:09:26
Quadro Congelado:
Tensão: 12.50 V
DD
Temperatura: 22.0°C
Torque: 3.8 Nm
Torque: 0.000 Nm
Borne 15 ON
Boa tarde troquei a direção assistida com uma com a mesma referência em segunda mao e está a functionar perfeitamente mas tenho estes error agora que nao sei rezolver
Tipo de Chassi 1K0)
04-Angulo direção -- Estado: Não pode ser acessado 1100
19-Gateway CAN -- Estado: Avaria 0010
44-Direção assistida -- Estado: Correto 0000
Versão: 00H30001
6 Avarias detectadas:
01309 - Unidade de comando da direção assistida (J5)
Quadro Congelado:
Estado de Avaria: 00100100
Data: 2015.10.04
Tempo: 13:46:56
Quadro Congelado:
Conta: 2
Conta: 0
Conta: 29184
Conta: 8213
Conta: 39424
Conta: 0
Conta: 256
Conta: 0
00668 - Voltagem de alimentação terminal 30
Quadro Congelado:
Prioridade de Avaria: 1
Quilometragem: 230291 km
Data: 2015.10.04
Tempo: 00:00:45
Quadro Congelado:
Conta: 7
Conta: 3
Conta: 4608
Conta: 128
Conta: 26112
Conta: 1
Conta: 256
Conta: 0
Quadro Congelado:
Freqüência de Avaria: 4
Data: 2015.10.04
Tempo: 02:11:23
Quadro Congelado:
Conta: 0
Conta: 0
Conta: 12800
Conta: 321
Conta: 50705
Conta: 10307
Conta: 7168
Conta: 0
00778 - Sensor do ângulo de direção (G85)
Quadro Congelado:
Estado de Avaria: 01100100
Data: 2015.10.04
Tempo: 12:39:56
Quadro Congelado:
Conta: 0
Conta: 2
Conta: 29184
Conta: 166
Conta: 49920
Conta: 512
Conta: 256
Conta: 0
000 - -
Quadro Congelado:
Data: 2015.10.04
Tempo: 00:36:23
Quadro Congelado:
Conta: 3
Conta: 2
Conta: 29184
Conta: 320
Conta: 50688
Conta: 0
Conta: 256
Conta: 0
008 - Sinal inadmissível
Quadro Congelado:
Estado de Avaria: 01101000
Data: 2015.10.04
Tempo: 00:00:25
Quadro Congelado:
Conta: 2
Conta: 2
Conta: 20992
Conta: 8212
Conta: 39680
Conta: 0
Conta: 0
Conta: 0
Versão: 00003001
1 Avaria detectada:
Quadro Congelado:
Quilometragem: 230292 km
Data: 2021.05.13
Tempo: 00:33:01
Incapaz de comunicar com o endereço 09. Estão travadas as portas?
Codificação: 100001
Codificação: 170F00
1 Avaria detectada:
Quadro Congelado:
Data: 2015.10.04
Tempo: 00:33:02
N° de Serie:
Codificação: 000000
Componente: EPS_ZFLS Kl. 233 3001
Versão: 00H17000
Nº Oficina: WSC 60498 004 1048576
Endereço 46: Conforto
DeyColioo
