Bateria descarrega...
pmjgomes
Veículos: Volkswagen Golf Plus 2.0 TDI 140cv
Mensagem por pmjgomes » 04 Jan 2012, 11:45
Olá,
Estou com um problema no meu VW Golf 2.0 TDI de 2006.
Se ficar mais de 24 horas sem ligar o carro a bateria descarrega... A bateria é nova.
Liguei o carro ao VAG e deu este relatório:
Tuesday,03,January,2012,21:28:13:10074
VCDS Version: Release 10.6.4 (x64)
Data version: 20110418
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76 7D
VIN: WVWZZZ1KZ6W509372 Mileage: 173640km/107894miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Sporadic communication error 1000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Sporadic communication error 1000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 1010
42-Door Elect, Driver -- Status: Malfunction 1010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Sporadic communication error 1000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: Sporadic communication error 1000
72-Door, Rear Right -- Status: Sporadic communication error 1000
76-Park Assist -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 T HW: 028 101 195 6
Component: R4 2,0L EDC G000SG 7001
Revision: 12345678 Serial number: VWZBZ0E0147461
Coding: 0000072
Shop #: WSC 00066 001 57865
VCID: 346318E32EAB
1 Fault Found:
16502 - Engine Coolant Temp. Sensor (G62): Signal too High
P0118 - 000 - -
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 Q HW: 1K0 907 379 Q
Component: ESP FRONT MK60 0102
Revision: 00T12001
Coding: 0023282
Shop #: WSC 01392 785 00200
VCID: 408B44336A13
No fault code found.
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1K0 907 044 AT
Component: ClimatronicPQ35 066 0606
Shop #: WSC 00000 000 00000
VCID: 79FDE9D74949
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000001877655
Coding: E5890F2700041800000A00000F00000000085D035C
VCID: 2B51039FF395
Part No: 5M0 955 119
Component: Wischer VW359 012 0402
Coding: 00065493
Shop #: WSC 01392
Part No: 1K0 955 559 S
Component: RegenLichtSens 010 1011
Coding: 00208933
Shop #: WSC 01392
6 Faults Found:
02071 - Local Databus
004 - No Signal/Communication - Intermittent
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
00447 - Function Limitation due to Over-Voltage
001 - Upper Limit Exceeded - Intermittent
00446 - Function Limitation due to Under-Voltage
01520 - Rain and Light Recognition Sensor (G397)
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
006 - Short to Plus - Intermittent
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 N HW: 1K0 909 605 N
Component: 1R AIRBAG VW8 015 2100
Revision: 03015000 Serial number: 0038ED0EJ4J8
Coding: 0012626
Shop #: WSC 01373 785 00200
VCID: 37792FEF3FDD
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AF HW: 1K0 953 549 AF
Component: Lenksäulenmodul 634 0070
Coding: 0000042
VCID: 76E7E2EB7857
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K0 920 862 B
Component: KOMBIINSTRUMENT VN4 5810
Revision: V0002000 Serial number: 00004294896601
Coding: 0003103
Shop #: WSC 21200 261 15572
VCID: 295DF997F969
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 2800105604037D
Coding: 3D3F0F40079002
VCID: 2A5F069BFC6F
7 Faults Found:
00474 - Control Module for Immobilizer
01317 - Control Module in Instrument Cluster (J285)
01333 - Door Control Module; Rear Left (J388)
01334 - Door Control Module; Rear Right (J389)
01320 - Control Module for Climatronic (J255)
01331 - Door Control Module; Driver Side (J386)
01332 - Door Control Module; Passenger Side (J387)
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VN4 5810
Shop #: WSC 06402 145 00197
VCID: 295DF997F969
1 Fault Found:
01176 - Key
008 - Implausible Signal - Intermittent
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX2.lbl
Part No: 1K0 959 701 L
Component: Tuer-SG 024 2417
Coding: 0000182
VCID: 37792FEF3FDD
1 Fault Found:
00932 - Electric Window Motor; Drivers Side (V147)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
VCID: 326F1EFBD4BF
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 01C802087F2D8405484F06F010CC
Shop #: WSC 00046 412 819200
VCID: 79FDE9D74949
Part No: 1K0 951 605 B
Component: LIN BACKUP HORN H07 7001
Component: NGS n.mounted
Component: IRUE n.mounted
1 Fault Found:
01134 - Alarm Horn (H12)
000 - - - Intermittent
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX2.lbl
Part No: 1K0 959 702 L
Coding: 0000182
VCID: 387B2CD332C3
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 5M0 035 195 A
Component: Radio BVX 014 0014
Coding: 0040400
VCID: 2A5F069BFC6F
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 F
Component: Tuer-SG 021 2424
Coding: 0000144
VCID: 33611BFF2BA5
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 F
Coding: 0000144
VCID: 346318E32EAB
Address 76: Park Assist Labels: 1K0-919-283.lbl
Part No: 1K0 919 283 A
Component: 24 Einparkhilfe 0101
VCID: 2D550D87CD81
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D550D87CD81
End ---------------------------------------------------------------------
Alguém me pode ajudar?
Cumprimentos,
Pedro Gomes
afan
Re: Bateria descarrega...
Mensagem por afan » 04 Jan 2012, 15:03
Instalaste alguma coisa recentemente, tipo RNS510?
Limpa os erros, dá uma volta c o carro e faz relatório de novo... :roll:
pmjgomes
Mensagem por pmjgomes » 04 Jan 2012, 15:15
Não instalei nada.
O carro vem com o RCD 500 que está com um problema na leitura de cd's.
Os erros foram limpos após a instalação da bateria nova.
Não pequei no carro durante 24 horas e fiz o relatório que está no meu post anterior.
Cumprimentos,
Pedro Gomes
cristo_844
Veículos: GOLF V
Mensagem por cristo_844 » 04 Jan 2012, 16:13
VCID: 2A5F069BFC6F
7 Faults Found:
se depois de limpares os erros o que esta em cima não desaparecer muito provavelmente foi a can que deu o peido mestre!!
e por causa disso que te esta a comer a bateria....
A Gente pensa que sou mecânico...pior Engenheiro! :lol: :lol: :lol: :lol:
Não respondo a PMs de users com pouca participação no fórum!!
pmjgomes
Mensagem por pmjgomes » 04 Jan 2012, 16:41
Vou testar essa possibilidade.
Cumprimentos,
Pedro Gomes
pmjgomes
Mensagem por pmjgomes » 06 Jan 2012, 13:38
O meu problema continua... :(
Ontem á noite a bateria já não tinha carga suficiente para pegar/arrancar o carro...
Quando disse que ia testar a possibilidade que o cristo_844 sugeriu, na verdade o que fiz foi sugerir essa possibilidade ao mecânico que está encarregue de resolver o problema. Pois como o carro está na garantia tem de ser ele a resolver...
Pelos vistos ele não sabe interpretar o relatório, pois foi apresentá-lo à VW para ter uma opinião.
O rádio (RDC 500) está com problemas, não lê CD's e tem de ir para arranjar e portanto ele vai retirar o rádio. Isso resolve o problema? E quando se voltar a ligar o rádio (mesmo reparado)?...
O mecânico diz-me que a can bus pode ser muita coisa e que não é assim tão fácil de perceber de onde vem o problema...
Enfim... grande confusão! Comprei o carro, faz hoje 1 mês e quase não usufrui nada dele e já começo a fica com a cabeça em água com esta situação.
O que devo fazer? Sugestões?
Cumprimentos,
Pedro Gomes
cristo_844
Veículos: GOLF V
Mensagem por cristo_844 » 06 Jan 2012, 14:00
VCID: 2A5F069BFC6F
7 Faults Found:
cada erro desses e um modulo electrónico do carro que não comunica com a can-bus...a can bus e um modulo que gere tudo que e electrónico no carro!!
esta localizado por cima do pedal do acelerador ao lado da coluna de direcção!!
quando não a comunicação com a can bus os vários módulos não desligam internamente e consomem a bateria!!
isso ou e a rede can bus com defeito,todos os módulos em cima avariados mas o mais provável e ser a can avariada...vai a sucata e arranja outra para testar!!
cristo_844
Veículos: GOLF V
Mensagem por cristo_844 » 06 Jan 2012, 14:04
já verificas-te todos os fusíveis??
pmjgomes
Mensagem por pmjgomes » 06 Jan 2012, 14:54
Cristo, mais uma vez muito obrigado pela tua ajuda.
Eu até condigo perceber tudo o que dizes e se o carro já não tivesse na garantia tratava eu do assunto rapidamente (acho eu).
Penso que o mecânico já verificou os fusíveis. Por mais que eu lhe diga/sugira para ele arranjar mudar a can, ele diz sempre que isso não é assim tão fácil e tal e que tem de fazer testes... Enfim...
Infelizmente, vou ter de esperar... :(
Cumprimentos,
Pedro Gomes
LuisSousa
Veículos: Golf V 2.0 tdi
Mensagem por LuisSousa » 08 Jan 2012, 13:38
boas, ao meu também acontecia isso, era o rádio que estava a meter a bateria a baixo, levei ao meu mecânico, e o eletricista meteu eu botão que conta a corrente toda ao rádio, sempre que paro o carro à noite desligo o botão de manhã quando pego no carro ligo e está como novo, nunca mais aconteceu nada.
mas o teu pode não ser isso.
cumprimentos.
cristo_844
Veículos: GOLF V
Mensagem por cristo_844 » 08 Jan 2012, 21:24
LuisSousa Escreveu:boas, ao meu também acontecia isso, era o rádio que estava a meter a bateria a baixo, levei ao meu mecânico, e o eletricista meteu eu botão que conta a corrente toda ao rádio, sempre que paro o carro à noite desligo o botão de manhã quando pego no carro ligo e está como novo, nunca mais aconteceu nada.
cumprimentos.
ate ao dia que te esqueceres de desligar o botão e ficas a pé!!
afan
Mensagem por afan » 08 Jan 2012, 22:42
cristo_844 Escreveu:
cumprimentos.
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
LuisSousa
Mensagem por LuisSousa » 08 Jan 2012, 22:56
afan Escreveu:
cumprimentos.
estou sujeito xd
mas para já foi a melhor solução
pmjgomes
Mensagem por pmjgomes » 09 Jan 2012, 16:28
Viva,
Antes de mais, agradeço ao Luis pela dica. :)
Agora o ponto de situação... O carro está na oficina e o mecânico retirou o rádio. Após 1 dia e meio o carro pegou normalmente sem indicios de que tenha descarregado a bateria.
O mecânico pediu-me para fazer este teste durante mais 48 horas...
O que eu penso... Eu acho que o carro vai pegar normalmente. Pelo que já tinha percebi do é o rádio que está a comer a bateria durante o tempo em que o carro está desligado.
O mecânico acredita que após o rádio vá a arranjar, quando o ligar fique tudo bem... Eu não acredito. Pois acredito que há alguma coisa que faz com que não corte o consumo do rádio de bateria enquanto o carro está desligado ficando a mesma descarregada. O que acham?
Eu falei-lhe mais uma vez na questão da can bus e lá começou novamente a enrolar a dizer que até a própria VW diz que não é assim tão fácil, pode ser várias coisas e tal... E que uma can bus ainda é cara (cerca de 600€) e tem de ser programada mesmo para o carro e não sei mais o quê...
O que me aconselham? Na 4ª feira o carro vai pegar normalmente quase de certeza (pois tiraram o rádio), acham que vale mais pedir para enviar o carro para a marca? Ou também acham que é possível que sendo o rádio reparado e montado no carro, problema resolve-se?
Estou prestes a ficar maluco com esta situação. :(
Cumprimentos,
Pedro Gomes
cristo_844
Veículos: GOLF V
Mensagem por cristo_844 » 09 Jan 2012, 16:33
a can nova custa menos de 200 euros..na sucata arranjas isso por uns 50 euros!!
e sim tem de ser programada ao carro...
qual e o radio que tens??mete uma foto se possível!
se precisares de uma can eu tenho que te posso dispensar!!
