Boa tarde, tenho umas questões relacionadas com este software, será que alguem entendio na materia me pode dar uma ajuda do que sabe ? Cumprimentos !!! 8)
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 C
Component: CLIMATRONIC C 0.7.0
Coding: 01000
Shop #: WSC 00046
VCID: 21498FE2AB08C04A8F-5210
2 Faults Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
00779 - Outside Air Temp Sensor (G17)
30-00 - Open or Short to Plus
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 A
Component: 0F AIRBAG VW5 01 0004
Coding: 12358
Shop #: WSC 31414
VCID: 35614BB20F805CEA43-4B1A
5 Faults Found:
00588 - Airbag Igniter; Driver Side (N95)
32-00 - Resistance Too High
01218 - Side Airbag Igniter; Passenger Side (N200)
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
01221 - Crash Sensor Side Airbag; Driver Side (G179)
28-00 - Short to Plus
01222 - Crash Sensor Side Airbag; Passenger Side (G180)
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AH
Component: 4E Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 00046
VCID: 0407E67614DA356284-4B1A
Subsystem 1 - Part No: 1J1959801C
Component: 4E Tõrsteuerger. FS0002r
Subsystem 2 - Part No: 1J1959802D
Component: 4E Tõrsteuerger. BF0002r
Subsystem 3 - Part No: 1J4959811C
Component: 4E Tõrsteuerger. HL0002r
Subsystem 4 - Part No: 1J4959812C
Component: 4E Tõrsteuerger. HR0002r
6 Faults Found:
01389 - Tailgate Open Switch (F124)
27-00 - Implausible Signal
00953 - Interior Light Time limit
25-10 - Unknown Switch Condition - Intermittent
01331 - Door Control Module; Driver Side (J386)
53-10 - Supply Voltage Too Low - Intermittent
01332 - Door Control Module; Passenger Side (J387)
01333 - Door Control Module; Rear Left (J388)
01334 - Door Control Module; Rear Right (J389)
ERROS VAG COM
- Veículos: Golf IV TDI
Re: ERROS VAG COM
nelsonrodrig
golf mk3 variantviewtopic.php?f=19&t=109474
Feedbackviewtopic.php?f=40&t=24409&p=736068&hil ... ig#p736068
- Veículos: Golf 4
Re: ERROS VAG COM
Tens aí muitos problemas para tratar... só do módulo confort são uma porradao deles ...
Vais ter que gastar algum dinheiro e bastante tempo para colocar isso tudo a bombar. Digo isto porque a minha praia é a eletrónica dos carros...
